Carl wrote:
9-series bikes come with the full set of monospacers, so you should already have them...but more to the point, from your question I take it you're already running one of the higher spacers, either the 35mm or 45mm...in which case you could've hit the same pad position with one of the Medium (height) stems and the lowest monospacer...and the reach difference between the medium-near & medium-far combined with the allowable mono cut length should get you where you want to be.
Hi Carl,
At the moment I have the low far stem with the 15mm mono spacer,I have the other 3 spacers also,it looks good as it is and it was only to get it into the UCI legal bb to tip of shifters I had the prob,there is 25mm to the trime line so ill only by about 5mm over the 80cm limit for 2014, if I was to get the low med stem I take it that would sort my prob,
Thanks Noel,
