The basebar will come back towards you about 20mm and be about 25mm lower on the small vs the medium (with the same stem). That means it gets closer to the basebar reach from your fit session, but further away from the stack. I don't know if that's still an issue for you, because I don't know what importance you place on the basebar position...or why. Your fit session involved a Zipp Vuka bar...by accident or by choice, I don't know...and where the bullhorns ended up in space probably had more to do with the very short-reach design of that bar than with any fit-related decisions.
If I'm wrong about that -meaning your fitter spent a bunch of time dialling a basebar position and it's a dealbreaker for you - I'll say you can get closest with the medium-near stem (15mm lower and 40mm longer than your fit session #s) and still hit your armpad coordinates...but that risks bringing the SC bar back far enough to come in contact with your knees when standing or (less likely) even while sitting. If you came up 5mm higher at the pads the same stem on a medium would nail the basebar stack and be 60mm longer than your fit session #...compared to over 100mm longer using the medium-far.
Carl Matson
Carl Matson
