Excellent thanks Gman and Carl.
Re: 2014 Speed Concept? [GMAN19030]
Re: 2014 Speed Concept? [Carl]
Carl
Thanks for that. Picked the bike up last week and all is great so far.
I am looking to change the brake pads and was wondering if you could confirm the type that I would need to get. I am thinking of getting the same Swissstop Yellow as per old bike, but they do sram/shimano and other versions. Which should I get for the 9?
Cheers
Chris
On the internet, you can be anything you want. It is a pity so many people choose to be stupid.
Cheers
Chris
Re: 2014 Speed Concept? [chrisbint]
you'd want the SRAM/Shimano version...not Campy.
Carl Matson
Carl Matson
Hi Carl- Thanks for all your help on the board. Question about the difference between the SC 7.5 and 9 series seatpost . I know the 7 series is alu and the 9 is carbon, but are the internals the same, ie, the di2 battery mount?
Re: 2014 Speed Concept? [JPDMD25]
You're very welcome.
Only the carbon post has the mounting provisions for our internal battery bracket.
Carl Matson
Carl Matson
I think the website might need updating. Thanks again for the clarification.
Re: 2014 Speed Concept? [Nick_Barkley]
Unless it is structural part or for storage is not the fairing under the bottom bracket illegal with USAT?
Official Polar Ambassador
http://www.google.com/...P7RiWyEVwpunlsc2JtQQ
Re: 2014 Speed Concept? [Bmanners]
It's as legal as the P5/Magura front brake cover fairings...which is to say, like Cervelo, we asked.
Carl Matson
Carl Matson
Carl (or anyone else who may be in the know),
Where can I find a service manual for a 2014 SC9.5? I can see the 2011 service manual on the Trek site, but nothing regarding the new bikes.
Re: 2014 Speed Concept? [KoopaTroopa]
Awesome. Thanks!
Hey Carl - I'm trying to adjust my fit on my 2014 and it seems that the pivot cradle is affixed to the mono extension. I pressed fairly hard on it and it's not moving. Is this typical or am I missing something here?
Re: 2014 Speed Concept? [vicmasters]
Thank you, but I did try that - I pulled the set screw completely out and freed up some housing (Di2) and it's still frozen in place. I'm happy to lube it in some fashion, but wanted to check first.
OK...wanted to make sure we ran down the easy ones first :-)
Take a look at the lower surface of the mono, particularly the edges of the slot. They should have a radius to them...if they're squared off they may grab that centering detail on the pivot cradle. A light touch with some sandpaper should do the trick to round them off and get things moving again...just check as you go to see when things are freed.
Carl Matson
Carl Matson
Same thing happened on my 7.5. When I disassembled it is when I discovered my LBS had not taken the window out of the wire covering and the wires were pinched, which we talked about in an earlier post. I filed and sanded some, but it was still a very tight fit and would not slide at all. I ended up getting it set by just moving the block and tightening everything back down and it seems good now. I thought the mono bar should move easily for adjustment and after reading this I guess it should. Not going to worry about it as I should not have to adjust it again.
Carl-
I think this has been asked before, but I didn't want to read through everything again...sorry!
Is the front-end of the 7.0 upgradeable to the integrated front-end of the 7.5? If not, do expect that there will ever be an aftermarket option to do so?
Thanks!
Thanks!
Re: 2014 Speed Concept? [rowotter]
Hi there-
It's upgradeable, and there's even a form for that on the Trek dealers ordering system (Dexter).
Carl Matson
Carl Matson
Re: 2014 Speed Concept? [efntm1432]
efntm1432 wrote:
I was just at the trek store and they told me if I wanted to travel with the bike I would be out of luck with the trek. He did say it would be ok if I used a transport co. But that would only be avail for big races not smaller races like b2bAnd I can answer for Carl here cuz recently I travelled with my new SC in my BikeBoxAlan.
I dismantled the whole cockpit and brake cables. All I removed were only a few bolts and the job was made even easier with Di2. I did take a bit more time assembling because I wana be dead sure that everything is running smoothly on race day.[/url][/img]
Thanks Carl!
If I talk to my dealer, will that part be obvious for them to find? Can you share the cost for these parts?
Does that module rest on top of the existing fork/steerer, or does the entire front end get replaced?
Does the upgrade make the front-end identical to a 7.5?
Thanks again-I really appreciate it!
My pleasure.
It's not a single part, it's a form which lets you choose the stem, mono shape, etc. Basically, you're replacing the bar and stem hardware from the fork upwards. I was able to find it by searching Dexter on "Speed Concept Upgrade". Your dealer is the best source for pricing.
Carl Matson
Carl Matson
Thanks again.
Does that upgrade make the front-end of the 7.0 identical to the 7.5?
Carl wrote:
... it's a form which lets you choose the stem, mono shape, etc. Basically, you're replacing the bar and stem hardware from the fork upwards.so, whether or not you end up exactly like a stock 7.5 is up to you.
Carl Matson
I got it out. The sticking point was the tab of the cradle that sits up into the cut-out of the extension. I had to forcefully (but gently) tap it out from there. I sanded down the tab ever so slightly and now it moves, if reluctantly. Thanks!
read your blog about iron project. inspiring bro. triathlete in SG also. awesome looking bike :)
