Doesnt seem like there will be slack for the cables to lay it down or am I missing something?
2016:
IMFL #12
http://www.bestbikesplit.com
Low Near W326769
Low Far W326770
Med Near W326771
Med Far W326772
High Near W326773
High Far W326774
I don't know if there are any Trek dealers in Brazil who are set up for customer-based online ordering of parts. Any Trek dealer should be able to order the right cover for you though.
The new Di2 junction boxes (3-port and 5-port) were designed for external installations. You might be able to fit it inside a High Near or High Far stem, but even then it's likely to be a tight fit. Accordingly, we designed the stem covers with four thin-walled sections which you can see on the inside of the cover...they're easily drilled out so you can run zipties to fasten the junction box to the cover.
