Carl : Thank you for the detailed answer! One more precision regarding the medium frame options...
Will my 760mm BB to Grip Reach dimension (incl di2 shifter pods) be a problem with either low stems i looked into for the MED frame, knowing that i will have a di2 junction box (may limit back position of the mono, knowing I want to run a bottle on the mono so puttiong the JB there is not OK) and the available cut length of the S Bend bar?
From "base Bar Reach" dimension, is there an equation that can give you the range of the extensions end position? That could help other people to check that parameter.
Thanks again for your feedback. This info is not on the chart and I would hate to spend so much $ to find out I ordered the wrong size.
T. Guertin / Spocket
