Carl can i pick your noodle for a moment please.
To adjust the tilt of the bars, i assume you undo the tiny set screw then the two bolts above that (after taking the pad wings of ofcourse) and adjust the tilt then redo bolts then set screw? is this correct? I hear angling up can be a bit more aero....wich leads me to another question- for a smallish tilt up, in regards to fit, i believe the pads should move forward a tad (am i missing anything else? dont really want to mess with seat height etc, im on adamo). To do so i have the option to move the pad cradles another hole, or i could move the whole bar when adjusting the tilt? do you have any recommendations? Thanks for your help! PS- tell the project one boys and girls to bring back that spartacus frame!
