it's in here:
http://www.uci.ch/...1.01-ENG_English.pdf the relevant section begins at article 1.3.021 on page 19, and in particular page 39 where you find (emphasis mine):
FUSELAGE “A fuselage form shall be defined as an extension or streamlining of a section. This shall be tolerated as long as the ratio between the length L and the diameter D does not exceed 3.
This rule does not apply to frame and fork of the bicycle.”
so, 3:1 no longer in effect for frame and fork, which must still meet the regulations regarding 8cm max depth and either 1cm min width (fork blades, seatstays and chainstays) or 2.5cm min width (all other frame tubes).
the previously non-UCI SC fork is now UCI legal.
Carl Matson
