Hi Carl, how difficult is it to replace the rear derailleur cable?
I suspect that my rear derailleur cable is frayed because no matter what I do I can't get the rear to shift properly. The bike is new but due to a frame issue it was rebuilt with a new frame. The rear shifting is no longer working right since: once I set the low limit and tighten the cable I takes 3-4 clicks to get it to shift into the next cog higher. I tried to increase the cable tension but it will still skip 1 click and with too much tension it won't shift back down into the lowest gear (smallest cog).
I think when they rebuilt the frame they reused the old shifter cable and it's probably frayed or something.
Before I take it to the shop I wonder if I could fix this myself. I recabled my old Cervelo P2C many times. I see the Speed Concept has housing running internally so is this as easy as taking the old shift cable out and pushing the new one in or does it require brain surgery to get it to pop out the other end?
Thanks!
Thanks!
