both sizes would give you room to go up without changing stems...XL would have more room, but I agree the Large seems more appropriate based on your other numbers.
the 841 max saddle height figure (for a Large) applies to the old bike, not the new one. on the new bike max saddle heights are listed to the rails, not the top of the saddle (since every saddle is different). with a 3mm setback the most appropriate post is the 15mm offset, which will go to 796 at the rails...measure your saddle height from rails to top and add to that # to see if a Large will work for you. XL can hit 820 at the rails with the same post.
Carl Matson
Carl Matson
