dkennison wrote:
The Garmin mount will be fixed to the screw on fill cap (front center). Left is the straw attachment point. The large lower piece between the extension tubes is hollow and will hold 29 oz of water.
The secondary mount shaped like a "T", the cage and upper bottle can come off.
So - just run the lower unit for Olympic distance and shorter. You have water and computer mount.
For longer distance use the lower unit for 29 oz concentrated liquid nutrition. Add the upper unit "T" mount, cage and bottle and use that to swap out "on course" liquid.
That’s interesting. How easy will just the “base unit” be to remove and empty/drain/clean out?
Also I wondered if you considered a nose cone/bento type unit that integrated to the stem cover/head tube similar to a Scott Plasma Premium or Canyon Speedmax type of setup? That seems to be the most aesthetic solution and keeps everything indepedent of the extensions so it’s not affected by risers or tilt.
