Hello all! Long post warning..
First off, shout out to Dan for answering questions about the tactical for me for the past month as I set my bike up. He truly couldn't have been more prompt or helpful through the whole process. Amazing!
I finally took my first ride today, and couldn't be more excited. I have a few random questions/comments that I was going to text Dan, but I figured there'd be interest for others as well on these considering the specificity:
-when I put the bike in the case, the derailleur is scary close to the zipper of the bag. My case didn't come with a derailleur cage, and even with the straps tight, I'm afraid the rear derailleur is going to take some weight of the bike. Any thoughts?
-is there a proper orientation to fit the rear and front wheels in the case? I couldn't figure a difference between my 2 wheels.
-i have a small, flat, black trapezoid shaped piece with two holes. What is this for?
-how do replacement pads work? I'd like to swap the forearm pads out
-I tried to find a way to arrange my spacers so that the di2 cable cutouts ran on the inside of the bars, rather than facing out. I tried a million orientations and only seem to be able to make them face outward on one, inward on the other.
-I want to move my extensions back one hole. I'd love a diagram of the di2 wiring so I could rewire this quickly from the extensions. I haven't read up on it yet, but I would hope it's as simple as disconnecting from the end of the shifters, fixing the cable length.
Some things worth noting from set up
-you gotta push in the di2 connector a bit harder than I had realized. I emailed Dan that I was having connection issues, when I simply wasnt pressing it in enough. I still feel dumb about this.
-when you buy the bike, go out and grab a long 9mm Allen wrench for the rear storage. Only way to get it on and off.
The battery inside the seat tube fell down the shaft on me. I set a piece of tape as a "catch" about 4 inches down so it won't fall down anymore.
I guess my only bit of set up criticism is that my bike came with the oversized pulley unassembled. I tried doing it myself, but didn't have the proper equipment or knowledge to swap the derailleur cage. I ended up taking it to a mechanic which was fine, but I was hoping the bike would have been assembled to the point where I could have thrown the chain on and rode away.
So stoked to put some miles on this thing! Thanks for reading.
