Maka_tak wrote:
What are the best options for front end hydration if your running the P5d for Triathlon? Any tips on something fairly integrated?Very good question and I am anxious to see the replies as I am working on the same issue.
I think that the answer may depend partly upon: (1) whether you have the EX10 or EX11 speed riser/aerobar; (2) which aero bars you use; (3) whether you prefer a bottle that you remove from the mount or a bottle with a straw; and (4) where you want your computer mounted. In my case, I have the EX10 speed riser/aerobar with Zipp Vuka Shift AXS 90 aero bars and want a bottle with a straw (like the XLab Torpedo Versa).
The challenge that I have is that I like to have my computer in front of my bottle. With some mounts, on bumpier roads, either the bottle or the computer will bounce a bit on the aero extensions. I am currently using the XLab Torpedo Versa (I do not use the XLAB Versa mount because it places the bottle too far forward and it rubs and bounces on my aero extensions; instead, I mount the bottle cage directly to the riser and use the Cervelo Aerobar bottle mount https://www.tritownboise.com/...ar-bottle-mount.html). With this setup the only place to mount the computer is on top of the dolphin fin, but this is too far back for me. I want it up front.
The solution MIGHT be the new XLAB Torpedo Versa Slim which is specifically designed for the Cervelo EX10 and EX 11speed riser/aero bar (as well as the Trek SC and Argon 18 E-119).
I should note that I have also tried the Zipp Vuka Aluminum BTA and it did not work for me...the computer was rubbing and bouncing on the aero bars.
JasonGeorge: May 16, 21 6:19
