Hughbg wrote:
I recently made the same conversion from electronic to mechanical. My local bike shop had a bunch of mechanical grommets lying around, as most people convert to electronic. The hardest one to find is the seat tube grommet for FD. I ended up making one from an old bit of tubing. Looking at some other mechanical bikes, though, it looks like you might be able to leave the rubber piece in place, as it might be a straight enough run to avoid rubbing too much.
This site also seems to stock the various bits:
https://www.excelsports.com/...ajor=11&minor=11 Resurrecting an old thread.
Looking for a bit of help building a NOS P3 frameset. I contacted cervelo, and info for "old" models are no longer available, p2/p3 are only sold as complete bikes now and was told to just contact dealer to have it built instead of getting cabling instructions...Anyone have a copy of the P2/P3 frameset build guide PDF?
Alternatively, can anyone just confirm I have the end caps in the right spots and routing correct for this particular frameset:
RD: full housing out extension, in-line barrel adjuster, full housing down through the right-most three-holed spot behind the stem. Full housing down to bottom bracket. End cap at the end of this housing. Bare cable though BB guide, naked cable though chainstay, out the special plastic frame guide, end cap on housing for the start of the loop and endcap at the end of the loop.
Front: Full housing down left most hole of the three-holed stem entry, full housing down to bb, housing end cap here, bare cable through the guide, bare cable up to FD.
Thanks!
