TRO Saracen wrote:
Hi,
I am planning my 2018 season around the TrainerRoad Long distance (Base, Build, Specialty) plans.
'A' races next year are two Ironman's, 8 weeks apart. Of the two, the second is the more important and I would sacrifice fitness in 1 in order to be 100% prepared for 2 (even though I'd like to go well in the first as well).
I am not sure how to put the plans together with the following ideas:
1) Go though full Base/Build/Specialty through to Ironman 1, then after recovery week or 2 repeat the final 6-7 weeks of specialty again through to Ironman 2.
2) Start later so that Base/Build/Specialty goes through to Ironman 2, with Ironman 1 slotted in with a taper/recovery week before and after and accept this means being undercooked for Ironman 1.
3) Go though full Base/Build/Specialty through to Ironman 1, then do a mini programme through to Ironman 2 (say 2 weeks base, 2 weeks build, 3 weeks specialty or similar).
If anyone has any relevant experience/advice I would appreciate it!
Thank you.
Howdy,
Sounds like you've got a great 2018 ahead of you! We're stoked to be a part of it.
Our recommendation is under the impression you're pretty experienced. I'm assuming this due to you targeting two Ironman events 8 weeks apart. ;)
Feel free to make adjustments based on your experience recovering from an event of this distance as well.
Of your ideas, we lean towards suggesting a variation of your third option. Since your second event is a bit more important to you, we think taking 2-3 weeks to include some low-intensity riding will give you the opportunity to establish an even deeper fitness base for the second event.
A great progression following the first event would be to spend the next 2-3 weeks in the third section of the
Traditional Base training plan. This might be a light enough load that will allow you to shorten the duration of how long your originally intended to recover after the first event. If you think that's cutting things too close, feel free to include the extra recovery time.
We then suggest approaching these 4-5 weeks with what we refer to as a re-build approach. We suggest entering back into the your Build training plan; the first 4 weeks if you're carrying more fatigue, or the last 4 weeks if you're feeling more recovered. On that fourth and final week leading up to you event, consider swapping that week with the final week from the Specialty plan you completed earlier in the season before your first IM. This week 8 from that Specialty plan is structured as a taper week, so the workouts will hold off on a lot of the volume, but still maintain intensity to keep you sharp for the event. That is, unless you had another tapering strategy in mind.
Let us know what you think! Have a killer couple of races, and keep us in the loop on how everything goes.
Cheers
Get Faster with TrainerRoad
