garg wrote:
hi, i am currently using a set of powertap p1 pedals when i search for devices, i see 2 devices for my P1
1 of them seems to be connected via bluetooth and the other is connected via ANT
the one with bluetooth can be calibrated but when i try to calibrate the device connected via ANT it says calibration failed
how do i activate the ant connection instead of the bluetooth one as i would like to measure power from both legs instead of simply doubling the power output from the left leg (which is what happens when a bluetooth connection is used)
Howdy,
The P1 pedals come factory calibrated, but there is the need to periodically "zero" the offset. But there shouldn't be anything fouling up the manual zeroing over ANT+. :/
If you're unclipped and have made sure nothing is contacting either pedal but still can't complete the manual zero over ANT+, mind shooting us an email at support@trainerroad? We'll be happy to look into this. :)
One thing to mention is that zeroing the offset on the P1s will store on the pedals themselves. So when you do it over BT, the value will hold true for ANT+ as well. So you could just do the zeroing over BT, then jump over to ANT+ so you get the combined L/R power value. This is less than ideal, so if you're still unable to complete the manual zero over ANT+ send that email on over and we'll investigate.
Thanks!
Get Faster with TrainerRoad
