John Salt wrote:
Hey Bryce, Thanks for getting back to me!
I am trying to determine if you can have two accounts operating off the same PC or will we need a PC per account in order to ride together? Hey John,
Ah the automated response must have been added with the crazy increased volume we've been seeing, I'm sorry about that.
The best way for you and your partner to train at the same time on the same device is through the use of the Standard App and the Beta App. They can both run simultaneously, where one of you is signed into the standard app and the other is signed into the Beta version. The Beta version is almost exaclty the same as the production version so you will likely not be able to tell the difference :)
You can download the Windows Beta here:
https://www.trainerroad.com/download/beta# What devices are you planning to pair? If your devices are ANT+ compatible, then the simplest way to set it up is with two ANT+ sticks (one for each application). This allows one app to use one ANT+ stick to pair with one set of sensors while the other app does the same.
If you have any further questions, don't hesitate to DM me, I want to make sure you can get setup as quickly as possible :)
Get Faster with TrainerRoad
