texafornia wrote:
Can somebody tell me if you can set a countdown timer to auto-repeat? For example, can you set it for 46 seconds and to restart and repeat it for X times? And can it beep and buzz every time it hits zero and restarts?
It looks like the 910 had an autolap function that won't work in pool swimming mode. In the pool is actually where I want to use this.
Better yet, anybody have a user manual located online anywhere?
What are you trying to do? The rest screen in the swim mode is awesome. There is a lap timer, that counts up from when you started the last lap. So if you're doing 100yd repeats on the 2:00, you will see the counter and when it gets to 2:00 you leave for your next 100. Alternatively, if you are doing a set with xx seconds rest, there is a rest timer that starts counting up when you hit the lap button to rest. There are a total of 4 fields that you can configure. I have my other two fields set as last interval distance and last interval pace.
Alternatively if you just want to be reminded every 46 seconds, you can set the time alert to 46 seconds, and the watch will buzz and beep every 46 seconds. I use this on my long swims to stay on pace. It worked great with the 910xt, but the vibration is much weaker in the 920xt.
DFWTri wrote:
Where is the automatic Calibrate power meter functionality like the Edge 500 when it detects the PM?
I accidentally found it on my first ride clicking the ... button. 2nd ride nothing showing up to ask me to Calibrate.
Anyone have issues?
There isn't an automatic calibrate like on the 910xt. When a powermeter is detected, press and hold the "..." button and you can calibrate. Personally I hated the forced calibration on the 910 (and I guess the Edge 500 as well). When I'm indoors the calibration never changes significantly on my Quarq. When I'm outdoors, I prefer to calibrate on the fly after the temperature and barometric pressure have equilibrated.
