leschaf wrote:
Hi Chad,
thanks for the quick answer! I guess much of the progress is because I'm pretty new to structured training. Anyway, I'm very glad with the process.
Regarding the specialty, I have another question, which is basically, when to start and which specialty to choose.
My A race will be in mid-August. Because of some business trips and vacation plans, I have about 14 weeks for training after my return from the current trip in April. A specialty only takes 8, so the first question would be what to do with the remaining 6 weeks.
I guess this also depends on which specialty you recommend. The A race will be a ~200km race with roughly 4500m ascend (3 mountain passes in the alps), where I'll have to deliver reasonably high wattage for sometimes 2 hours straight. The recommendation for pacing seems to be about 70-80% FTP on each of the ascends to a mountain pass. The usual training recommendation seems to be to do a lot of longish (20-30 minutes) intervals, pretty much like, e.g., the Golgota workout in TR.
So, my situation is that I have 3-4 days per week where I can get on the bike, and I can do so for 2+ hours, so I'm not really limited to 1 hour workouts there. To me, the century mid-volume specialty with combining the two weekend workouts on one day makes more sense than the road climbing race specialty. Would that be a good choice? Also, would it make sense to replace some of the VO2Max units with more 2+ hours sweet spot work of roughly the same TSS? I really do not care much about my strength on short hills or tempo changes.
So, to sum up:
1) Which specialty would you recommend to me, and what changes should I maybe apply?
2) What should I do with the remaining 6 weeks?
Hi again,
You
could use those 6 weeks to repeat either SSB I or II if you think your higher-end endurance could use an extra boost, or you could perform a Re-Build where you repeat either the early or later 6 weeks of whichever Build plan best suits your needs, probably Sustained Power in your case.
Then, your Specialty plan could be either the the Climbing Road Race or Century (probably a better fit in your case) plans depending on which workout selection seems more interesting, which counts for more that a lot of riders recognize, and which is better suited to your event's demands.
And you're always welcome to modify workouts depending on your personal needs. For example, I often make my VO2max workouts a little longer overall and more dense and I also vary their intensity from set to set just to keep things engaging and because I've learned that my body responds well to this sort of workout alteration. Same thing with longer rides - if I feel up for it, I'll take on more miles/hours seeing to it that subsequent workouts don't begin falling short or my level of motivation isn't falling due to ramping things too quickly or too high.
Along these same lines, you may find that 95% repeats cook you inside of 3 or 4 intervals while 92% repeats or recoveries with an extra minute or two allow you to lay down more volume and better cater to your individual rates of adaptation & recovery.
I know it sounds like I'm trying to shift some of the design burden to the athletes, but the fact is, these training manipulations are all part of the process of becoming a better athlete from season to season - trial & error/dose & measure will forever be a part of this process if you want to make the most of your training time. ;-)
Head Coach at TrainerRoad
Co-host of the Ask a Cycling Coach Podcast
