HandHeartCrown wrote:
Howdy,
I have a quick (I hope) question on pre-existing run fitness and its potential (if any) to limit FTP improvement.
I purchased a Kickr at the beginning of the year and paired it with TR with the goal to improve my biking. Early on I did the 2x8min FTP test and received a value of 214 (I'm 53 years old, if that makes a difference). I then proceeded to follow (for the most part) the Sprint Tri Base program. After a month, I repeated the 2x8min test and received an FTP of 212 (effectively, no improvement). A bit disappointing, to say the least. I continued the base phase and switched over to the Build phase and repeated the 2x8min test eight weeks later. My FTP was again 212. It's nice to be consistent but I was hoping for an improvement.
I have a strong running background (19:30 5K, 1:30 Half Marathon, 3:15 marathon in recent history). Could the fitness I have from 20+ years of running be limiting my potential cycling improvement? I love the structured sessions TR provides so I will continue to use the application (one can't ride outdoors during a Boston winter anyways).
Thanks.
Hi, and thanks for your patience while I've been traveling.
First off, your running fitness will only come at the detriment of your cycling fitness if you're allocating precious bike time to something you're already good at - running. So unless you're neglecting your bike training and doting on your run training, I doubt that's the issue.
Secondly, let's consider the timing of your reassessments as well as how the workouts are progressing. If you feel like you're getting stronger and perhaps even lifting the Workout Intensity during workouts or simply feeling less challenged as the weeks roll by, there's a good chance your fitness is on the rise regardless of what your FTP assessments might indicate.
Similarly, when the workouts are getting tougher from week to week but you're dealing with the increases in stress and completing the intervals as prescribed, this too can demonstrate greater fitness that belies the results of your reassessments.
If you think this might be the case, try adding a priming workout on Monday prior to your assessment. Any of the Truuli workouts spring to mind since they're pretty short and not too high in stress but will very probably get your muscles and your head in the proper frame of mind for the next day's assessment workout.
The other likely culprit is too much fatigue and you can recognize this by the flat feeling you carry into each new loading week (i.e. the first post-recovery week). Sometimes an extra day or two of rest or active rest is necessary depending on how deeply the preceding 3 weeks buried you. Alternatively,
maybe the recovery weeks could be shortened by a day or two if you genuinely feel rested & ready to get back at it (though a less likely situation as a masters athlete).
And until your next assessment, don't feel locked into your current FTP if you feel like you're capable of more. Feel free to lift the Workout Intensity 2-3% and see how each workout goes. My bet is you'll find yourself getting through more challenging versions of your workouts once you account for the improvement your assessments aren't fairly demonstrating.
Head Coach at TrainerRoad
Co-host of the Ask a Cycling Coach Podcast
