KodioMN wrote:
Hi Mitch,
Could you point me to the best frame size + stem set up?
Arm pad reach (BB to back of pad) 512mm
Arm pad stack 680mm
Saddle height 821mm
Thank you
Kodi
Sorry for the late reply!
You're probably best fit with an XL frame, Medium-Far stem, and a 15mm Mono spacer. I would also run a Long seatpost with a 50mm offset if that saddle measurement is to the rails. If it is to the top, you can run a Long seatpost with a 15mm offset which maxes out at 820mm to the rails.
Mitchell Mathews | Community Manager | Trek Bikes | @mitchmathewz
