Re: Angled spacer [elf6c] [ In reply to ]
https://www.instagram.com/...utm_medium=copy_link
Jim is just toying with us now. Looks like we are getting closer with at least one pro on the new bike.
Yay for no more bb90.
blog
Re: Angled spacer [stevej] [ In reply to ]
You notice the bottom bracket area and the possible cutout (maybe not best description) on left side?
Re: Angled spacer [littlefoot] [ In reply to ]
Yeah it’s a threaded bb which likely is t47. I did notice the cutout which is similar to what Trek Segafredo has been riding this summer. I believe the UCI and Tri bikes are different but this may be one similarity they share.
blog
Link wouldn't work for me, who's IG account is it linking to?
Re: Angled spacer [KYRxTri] [ In reply to ]
ERO sports
blog
Thank you Stevej
I have a 2014 SC 7.0. I currently have vision bars on the front. After racing it for 7 years, I am thinking about having my local Trek dealer rebuild my front end.
Can I put an integrated front end on a 7.0 ?
Re: Angled spacer [Calvin386] [ In reply to ]
If you mean turning the front end of a 7.0 into the front end of a 9.0.....I don't think so?
But there are lots of really nice aftermarket bars out there that you could replace your visions with. Tririg for example. Or Zipp Vuka's, or 51 speedshop.
Re: Angled spacer [SBRcanuck] [ In reply to ]
Yeah that's what I was thinking. Integrating my front end like a 9.0. I still have IM Chattanooga left but I am planning on going through this bike after that. If I rebuild the front end, I might as well integrate it if it's possible.
Re: Bontrager Comp Road Pedal on SC [Mitch@Trek] [ In reply to ]
My fiancé has a 2012 speed concept with mechanical SRAM Force. It’s been a great bike, but after having a super hard time indexing the rear derailleur, we realized that the front derailleur and the rear derailleur cables are interacting with each other… in other words, when she shifts into the little ring, it pushes the rear derailleur out *just* enough to throw the indexing out of alignment.
Is there a simple fix for this? I’m guess to just try and see where the cables are crossing and address it, but I didn’t know if this was a common issue on the older mechanical systems.
@floathammerholdon | @partners_in_tri
Nope that will not work. A 7.0 and 9.0 are two totally different animals on the front end. There are some third party cockpits that can get you close to a SC 9 but not the real deal.
Re: Bontrager Comp Road Pedal on SC [cloy] [ In reply to ]
I've never heard of that happening. Maybe whoever assembled it crossed the cables somehow. I'd have it re-cabled at a good LBS.
Re: Angled spacer [Rideon77] [ In reply to ]
I thought there was a part that could be ordered that would essentially turn the 7.0 into a 7.5?
I swear I was told that by an employee of a shop selling treks. If not true, I'm glad I didn't buy the 7.0 (color preference) years ago.
Well, if nothing else, you'd at least need to source a 7.5/9 fork, along with the proprietary stem and bars. But I don't know for sure if the fork will properly fit a 7.0 frame.
Honestly you'd probably be better off finding a used SC9 frameset.
Thanks for the answers everyone.
I actually just looked at at frame set. That may be the way to go
I rocked a 2013 SC 7 series (without integrated front end) for a long time. I put a Tririg Alpha X on it and it hid cables quite well with the Tririg omega brake. Let me know if you'd want to buy the bars, I still have 'em.
Re: Official Speed Concept Owners Thread [wsrobert] [ In reply to ]
I finally switched from 700c x 23mm GP4000 to 700c x 25mm GP5000 and the bike is feeling great. My back brakes are squeaking though a little and I asked the LBS to fix, but they didn’t fix. I think I might need to sand the brakes or something.
https://www.strava.com/...tes/zachary_mckinney
Yes, you can modify a 7.0 into a 7.5(9.0 integrated aero bar) to transform it in the super bike version.
I did it.. you just need to order or find the hardware of the integrated cockpit.
Personally, I found the stem of the 7.0 pretty sketchy.. the integrated bar is a lot more robust/rigid.
Bigger pieces are:
- integrated stem (acc to fit needs)
- mono spacer (acc to fit needs)
- base bar ($$$)
- one of the aero bar options
- aero bar hardware kit (nuts and bolts)
- arm rest/pad kit
- the cross bar under the elbow cups
(This is what I remember on top of my head, might miss a piece or 2)
If still interested, I can provide more details, part numbers, the exploded view..
T. Guertin / Spocket
Re: Angled spacer [spocket] [ In reply to ]
And a fork for the hidden/integrated brake?
If not doing that, then why not just buy a tririg bar system?
If we are speaking of the gen2 SC, the front brake cover of the 7.0 was the same. The bottom of the stem/steerer adapter on the 7.0 is identical on the bottom portion and interface with the fork the same way.
Bigger pieces are:
- base bar ($$$)
- arm rest/pad kit
Thanks... PM sent
I assumed I would need a new fork. However, the 2014 7.0 fork has an integrated brake
2017 Stem and mono spacers [ In reply to ]
I'm picking up a really nice used 2017 7.5 on Saturday. It's setup high/close/high and I'll be looking for a few parts.
Primarily I'll need a Mid/far stem and a shorter mono-spacer to help tweak the fit.
Are those parts readily available at dealers or should I be asking if anyone has them sitting around ;)
Re: 2017 Stem and mono spacers [sbear55] [ In reply to ]
Just got a used 7.5 also and needed same.
I changed low far stem, mono extension plug in and 15mm mono spacer.
I have some parts. When you get it sorted let me know.
Re: 2017 Stem and mono spacers [Pwraddr] [ In reply to ]
I lucked out when I picked up the bike yesterday. He had the mid-far stem and shorter spacers in a spare parts bag! Those should, based on the eyeball test, get the position really close.
