Found too short?
Re: My testing to try and find best crank length with my Velotron [h2ofun]
Found too short?
Re: My testing to try and find best crank length with my Velotron [TriFluid]
TriFluid wrote:
Found too short?
But is there data? :)
Honestly, I would love to hear from folks on what the shortest cranks they have race on are? And what positives or negatives they found.
I have no desire to reinvent the wheel.
Dave Campbell | Facebook | @DaveECampbell | h2ofun@h2ofun.net
Boom Nutrition code 19F4Y3 $5 off 24 pack box | Bionic Runner | PowerCranks | Velotron | Spruzzamist
Lions don't lose sleep worrying about the sheep
Now I did trip and fall flat on my shoulder running on Saturday. I hope I did not break anything. Sure hurts and the bruise keeps getting larger.
I wonder if riding shorter cranks is making me more of a klutz? Going out for my long run in a few minutes as soon as it gets some light outside,
rather than the pitch black I am seeing out the window.
Seems that one of things I am seeing is a relationship, for me, between rpm and power. If I slow the RPM's down, like 70 to 80, I put out a lot more power compared to if I start to spin at lets say over 85 rpm. Is this expected?
h2ofun wrote:
Seems that one of things I am seeing is a relationship, for me, between rpm and power. If I slow the RPM's down, like 70 to 80, I put out a lot more power compared to if I start to spin at lets say over 85 rpm. Is this expected?Same happens to me,find it easier to keep power smoother,and higher and also heart rate is commonly lower too.
Re: My testing to try and find best crank length with my Velotron [Leeken]
Leeken wrote:
TINSTAAFL
FindinFreestyle: Dec 19, 17 11:13
Leeken wrote:
Great, at least I may not be totally dreaming this. I had thought that maybe 70 rpm was a good target, but maybe thinking 80 is better.
What is your target RPM for the flats?
Thanks
Re: My testing to try and find best crank length with my Velotron [FindinFreestyle]
FindinFreestyle wrote:
Leeken wrote:
TINSTAAFL
Okay for this old person, what does this mean?
H2Ofun wrote: "Great, at least I may not be totally dreaming this. I had thought that maybe 70 rpm was a good target, but maybe thinking 80 is better.”
Dave, it is all about pedal speed. As we shorten the cranks your best RPM will increase to keep your pedal speed near your optimum. If it is true that one will run better off the bike if they ride at a higher RPM we are approaching that goal as your “optimum" pedal speed at this power (as near as I can surmise) on 130 cranks will come with a cadence of 88. We will see if you can see this when you do your runs.
Frank Day
Frank Day
FindingFrestyel wrote: “TINSTAAFL”
Nothing free here. Just using knowledge to correct hidden inefficiencies. Improve efficiency, improve power. He (and all of you) have done the training you have. Dave has many years under his belt. Power improvements are really hard to achieve in an athlete like Dave. This is just an attempt to get the most out his well trained muscles. And, the other thing that isn’t “free” here is, if you haven’t noticed, Dave is working really hard to make these changes. It seems to be working. The rest of you could do something similar I am sure - unless, of course, you listen to the experts who hang out here. Won’t know who is right unless you try. :-)
Frank Day
Frank Day
h2ofun wrote:
H2Ofun wrote: "Great, at least I may not be totally dreaming this. I had thought that maybe 70 rpm was a good target, but maybe thinking 80 is better.” Dave, it is all about pedal speed. As we shorten the cranks your best RPM will increase to keep your pedal speed near your optimum. If it is true that one will run better off the bike if they ride at a higher RPM we are approaching that goal as your “optimum" pedal speed at this power (as near as I can surmise) on 130 cranks will come with a cadence of 88. We will see if you can see this when you do your runs.
Frank Day
I had a good time on my long run this morning, even though it was real cold, after riding 135mm cranks.
Wow, so you are saying I should try and keep cadence on 130's at 80? What should my cadence at 135's have been? When I went like at 85ish on the 135's, I saw my power go down, so I backed off back to 80 where I saw and felt the power go back up.
H2Ofun wrote: "Wow, so you are saying I should try and keep cadence on 130's at 80? What should my cadence at 135's have been? When I went like at 85ish on the 135's, I saw my power go down, so I backed off back to 80 where I saw and felt the power go back up.”
No, I said 88 on 130’s You were about perfect on the 135’s with a cadence of 82. Both will give you a pedal speed of about 1.2 m/sec.
Most of the people who are pedaling too fast should keep the cadence the same as they shorten their cranks as that slows the pedal speed and should result in improvement. You are pretty near an optimum pedal speed now for this power for you. If you keep the cadence the same as you shorten your cranks your pedal speed will soon be far away from optimum and it will hurt your performance. We did all that early work to find your best pedal speed. Now we need to try to keep you there as we make these changes.
Frank Day
Frank Day
In case anyone was confused as to what actual peacocks fornicating looked like...
FindinFreestyle: Dec 19, 17 17:28
In case anyone was confused as to what actual peacocks fornicating looked like...Thanks
at the risk of actually prolonging this death of this thread
https://www.youtube.com/watch?v=FG1NrQYXjLU
it just somehow reminds me of Billy Idol's 'Dancing with Myself'
sorry, everyone...
sorry, everyone...
Re: My testing to try and find best crank length with my Velotron [dtoce]
dtoce wrote:
at the risk of actually prolonging this death of this thread https://www.youtube.com/watch?v=FG1NrQYXjLU
sorry, everyone...
Great song thanks
And another
Quote:
It seems from some of your earlier comments that you were very critical of Dave’s efforts here yet it seems you have done much the same thing. Why the criticism?In other words, you didn't read very carefully...
"I'm thinking of a number between 1 and 10, and I don't know why!"
Re: My testing to try and find best crank length with my Velotron [Warbird]
Warbird wrote:
Maybe, maybe not
Did my 5 mile TT test on 130mm cranks this morning. They did not feel as weird as I expected. Will give them a try on my Martis ride tomorrow.
Still have yet to find too short is making my power numbers go way down. I wonder how short I have to go before I see this. Having to increase the rpm
rate as the cranks get shorter is interesting.
Warbird wrote: "In other words, you didn't read very carefully…"
I try to read everything carefully. All I can say is this is a thread talking about how crank length can be manipulated to optimize power and bike fit. You popped into this thread at post 1082 with this: "Because, unless your cranks are long enough that they restrict your movement, crank length doesn't really affect fit.” Now, if you had prefaced that remark with the words “I agree with Frank here …” there would be no error in your intent but you didn’t. There was no offer as to how you would find whether a crank was restricting movement or not. The purpose of that statement was interpreted by me that Dave was wasting his time going real short because you didn’t see any benefit. As I pointed out later after more detail was pried out of you it appears to me that perhaps one of the reasons you didn’t see any benefit was your testing procedure was flawed.
Frank Day
Frank Day
Did my Martis course this morning on 130mm cranks, avg 84 rpm. Still ended up with a decent time and power number. Had to get out of the seat more starting around 13%. Clearly, without move low gears, getting harder on real steep stuff, but again, overall, I have not seen any big drop off in stats. Guess I will have to try 125mm's tomorrow on my 5 mile TT loop.
Just got back from my long run this morning. Car said it was 25 degrees. COLD!
But, I had a good run time. So for the folks saying short cranks will destroy my run, again, I am not finding any data to say this is true.
h2ofun wrote:
Having to increase the rpm rate as the cranks get shorter is interesting.Given that you used to ride 200's at 95 RPM, to produce the same power on 130's at 85 RPM requires about 72% more pedal force. It's not surprising in the slightest that you might have to stand through some sections of your course.
Less is more.
