ctflower wrote:
h2ofun wrote:
Big Endian wrote:
h2ofun wrote:
Doing a new focus with my testing. Doing my 5 mile TT course in Aero and seeing what the numbers do. I continue to have been surprised the 150 cranks have allowed me to put out more power with my target 70-75rpm than 175. So I now am changing the crank length to see what happens with the numbers. Who knows, might even try to get to 135,
even though my seat would be low, just to see what happens.
You could move your cleats to mid-foot, that would take care of the low seat issue.
Because otherwise you're not changing enough things at once.
For clarity: When you say "doing my TT course in Aero" you mean "riding my velotron on a simulated course while in the aero position", right? Just making sure we are all on the same page here. What is it exactly that determines your progress along that course? A simulated power-speed-distance relationship? Rear wheel speed?
Yes, I am riding a flat course, which I assume saying it is a TT course is correct? It is 5 miles long. We are just collecting data by doing a few things. One is doing this on different crank lengths, in back and forth order. One I have at 150. I am now going shorter on the other. Was at 175. 170 this morning. Will go to 165 tomorrow.
Am also lowering the bars to see if I can stay in the aero for the entire time for fit and comfort. Was at 40mm drop this morning, will go to 50mm tomorrow.
I am also trying to focus on pedal speed around 70-75 rpm.
We are measuring HR, but the one of most interest to me is average power. So far, the 150's have much more for this 5 mile TT than 175 or 170.
So not sure about your last questions. This would be no different than if you found a 5 mile section of road, and road it with measuring variables, I believe.
The only thing I focus on is RPM, nothing else. If it drops below 70, I would have larger power but I do not have the strength to do that low and hard for long.
Any ideas for improvements? Maybe.
How many knobs are you tweaking at once? I'm not big on HR as a focal point for ME, but that's a metric of interest for YOU, so I'd do the following:
Fixed parameters
Course: 5 mile TT
Cadence: 70
Power: FTP (some effort, but nothing that should floor you for a 12 min effort)
Adjustable parameter:
Crank length: 150, 160, 170, etc
Output:
HR
Settle on ideal crank length based on your HR. Then move crank to a fixed parameter and redo the test with varying cadence to optimize that.
Trying to turn as few at once as possible. IMO, there is not specific thing we are tracking, just trying to track as many things as possible to see if there are trend. I was pretty surprised to see that over 80 ish, my HR really went up. Good or bad, just data.
Only thing fixed is 5 miles flat. I can change gearing to any RPM I want. Power is not fixed, I just am pushing with a steady effort. Not a TT effort. I have to run 9 miles after this like I did this morning. Or get on my treadmill for 30 minutes running 7:30 pace after a 6:30 10 minute warmup.
I have over the last few months tried setups at different crank lengths. Again, collecting data.
There really IMO is no output. Just collecting as many things as I can. Waking HR. In testing, HR, RPM, watts, mph. I also record my 9 mile run time after these efforts since it has been great with the time to tell me if I am recovered from being sick or a race.
We started out for a month testing over a various set of crank lengths and RPM with fixed 200 watts. My next testing will increase the watts to 220 and see what happens. Right now I am trying to see when the power goes up via crank length, or goes away getting too short like at 135mm.
</htm
Dave Campbell |
Facebook |
@DaveECampbell |
h2ofun@h2ofun.net Boom Nutrition code 19F4Y3 $5 off 24 pack box |
Bionic Runner |
PowerCranks |
Velotron |
Spruzzamist Lions don't lose sleep worrying about the sheep
