Kiwicoach wrote:
devashish_paul wrote:
h2ofun wrote:
Did Martis today on locked 150mm cranks. Had the fastest time ever on the course. Some thoughts. Over the years I have used lots of different cranks lengths. 200's, 175's, 185's. The common result is on a flat course, none of these different
crank lengths seem to make any different in my race times.
But since most races I do tend to have lots of big hills, I have been chasing, via crank length, how to get the best times. I had always read you must use long stuff
to get leverage, which is why I have used 200's for so long.
But, with the testing on the Velotron, I seem to have found results that say some of my past assumptions are wrong. Meaning, even in my testing on flat stuff, no matter what
the crank length, my result times are still all pretty close to each other. But in the hills, a huge difference between 125 cranks, and 150's .
Now, if I were in the past, I would have continued to assume well if 150 is good, 200 has to be better. But it seems I also now understand one has to throw in bike fit,
which I had never really added to my thinking. And it seems the shorter cranks has allowed me to get a better aero position, and deal with my knee issue.
Going to try the cranks in PC mode next and see what happens. With all this testing I have not done much PC riding lately, and I do not like that so need to add that back
into my trainer training.
Dave you need lower gearing to climb hills. You can get lower gearing three ways
- Bigger rear cluster (cassette)
- Small front chain ring
- Longer crank arms
Just so you realize your 150mm cranks are 33% harder gearing than your 200mm cranks (200/150 = 1.3333) items 1 to 3 being equal. So you're going faster on your hilly course with harder gearing (assuming your testing does not keep changing out casette and chain rings). So the answer to this 'seems' to be you are going faster due to better fit and PERHAPS better aeordynamics, not because of any magic crank length leverage (you're actually having to apply higher pedal force on the pedal at 150mm cranks to sustain the same crank torque as with 200m at a fixed RPM....and since Power = torque x RPM, you are applying higher pedal force on the 150mm cranks than with 200's assuming of course you are keeping the same power output and getting faster through superior aerodynamics at a fixed RPM.....or you are applying the same pedal force as with 200mm's but your moving at way higher RPM to sustain the same power.
But are you even measuring power on the road, or is it some bogus field test where you don't even control power, forget about controlling wind????
Sorry I have not been on this thread for a while, and maybe with the Xmas lull at work I don't feel bad squandering some time on ST, but it feels like nothing has changed in terms of your understanding of everything Biomcgeek has provided us the foundational knowledge for with countless hours of stringent science based peer reviewed results!!!
This is why I don't waste my time and the time of the World Class cyclists I coach on chasing the optimal crank length, it's simply not worth it.
http://wattagetraining.com/files/JMartinCrankLengthPedalingTechnique.pdf
Same goes for Gimmickcranks, well performed studies in credible journals highlight their lack of efficacy.
Dollars to donuts your good days are due to the training effect and your bad days are due to long term fatigue.
You may be right on crank length. But everyone is different. I do find a difference between 175's and 150's and 125's. As I just said to Dev, it is fun to see what happens.
If there is no difference, then I guess I do not understand why some suggest some should consider shorter stuff. Why not have everyone ride 175's?
I do love the powercranks and will continue to use since I feel very strongly they help my running. They even have helped show me my bike fit and crank length were the pits on
200 cranks since I could not even get in aero to pedal the cranks cleanly over the top.
Thanks for any inputs you are willing to give as I play with this stuff, for my learning.
Dave Campbell | Facebook | @DaveECampbell | h2ofun@h2ofun.net
Boom Nutrition code 19F4Y3 $5 off 24 pack box | Bionic Runner | PowerCranks | Velotron | Spruzzamist
Lions don't lose sleep worrying about the sheep
