Pyrenean Wolf wrote:
I'm 6' (183cm)
Currently I'm on a 54cm P3 (2014-later model). With longer stem, to accommodate longer Tri position. Used a shorter stem for UCI position.
With current P5D set-up charts, length-wise, with my tri position, I would need a 58cm P5D. 56cm is .... a bit short. And 58 a tad high.
Moving from 54 to 58 indicate P5D is currently... short, for tri use. Make sense as it is a UCI oriented bike, with the associated rules (for me, 75cm maximum BB to aerobar tip, horizontally. In tri, I'm much longer).
Of course, if in 10 days Cervelo present :
1) new cockpit solution for the P5D with more adjustability (more length, some angle to go med or high mantis, ...)
2) P3X with adjustability equivalent to P5X
... then it will be a brighter day for Cervelo lovers :-)
i don't understand how you would go from a 54cm to a 58cm, in bikes that have pretty much the same geometry. in went from a 56 to a 56.
Dan Empfield
aka Slowman
