Mitch@Trek wrote:
Hey David, we don't have any fit guide aside from our standard geometry chart for the Madone Speed, but I reached out to the product team to inquire. If I hear back, expect to see a file in another response to this message you sent.
Thanks Mitch.
The standard geometry charts for the Madone SLR have never been all that useful, I've taken measurements off a bike in order to be able to calculate fit.
If the product team do feel like sharing info I have a few other questions:
1. Height on the steerer axis of parts 5 and 2
2. Max steerer spacer height?
3. For the proper stem - is the bar clamp 31.8mm and it's just the interaction of bar and stem that limits the roll to 5deg? Would a normal bar fit?
4. Again for the SLR stem - height of the steerer intersection point on both angles?
5. What is the adjustment range of the seatposts? The chart gives min and max for short and long but not how much the ranges overlap.
6. What is the distance of the front of the rail clamp from the centreline of the posts for each post offset option? Also, length of rail clamp?
7. I can't find how Bontrager bar reach is measured - is it centre to centre or some other variant?
Moving on to the Speed
8. it looks like the tilt adjustment from the SC has not made it across to this bike?
9. There are high and low versions of part 10 (faceplate) - stack of each of those from the bar centre?
10. total stack from bar centre to top of pads
11. Max offset of rear of pads
The chain that is the primary Trek dealer here has 5 stores within an hours drive of me so I get quite a few clients sent in prior to Project One orders. Which means we all want to get things exactly right, plus I can save the store a lot of time with the aerobars by detailing exactly how to set up the slider and wing to avoid them messing around trying to match the position. Since Carl left I've not been able to get the information required to fit the new bikes properly.
