Tyrell wrote:
Mitch@Trek wrote:
Tyrell wrote:
Hi Mitch! I recently picked up a set of Aeolus 5 D3 TLR rim brake wheels. Love them except they feel a bit soft when cornering, like they are wanting to drift wide vs the aluminum hoops I'm coming from. Same rubber, same pressure. I'm thinking the spoke tension may be on the lower end of acceptable range? Can you advise the proper specs: front, rear DS, rear NDS.
THANKS!
Front DS: 153 lbs min OR 69.4 kgf
Front NDS: 253 lbs min, 340 lbs max OR 114.8 kgf min, 154.2 kgf max
Rear DS: 253 lbs min, 340 lbs max OR 114.8 kgf min, 154.2 kgf max
Rear NDS: 153 lbs min OR 69.4 kgf
Thanks for the quick reply, Mitch! Front DS/NDS having different specs sounds like these are for disc brake wheels though. Which figures should I use for rim brake?
My bad, read your message incorrectly!
Updated the numbers.
Front: 220 lbs min, 290 lbs max OR 99.8 kgf min, 131.5 kgf max
Rear NDS: 100 lbs min, 122 lbs max OR 45.4 kgf min, 55.3 kgf max
Mitchell Mathews | Community Manager | Trek Bikes | @mitchmathewz
