allenpg wrote:
That's odd...I just reinstalled everything on my new Slice RS frame with the same components as you. I used the 4 port junction in the chainstays to connect everything to a cable that ran up the downtube to the 5-port junction box, which connected to the shifters. Everything works fine for me. Have you taken yours to a shop to get it diagnosed the PCE1? BTW, I never used the 3-port junction which came with the bike, just the 5-port. I would also try hooking things up like you did prior to getting the 5-port junction and base bar shifters. This will help determine which components might be causing the problem. Good luck! -Pete
Thanks, as I've heard on this
Di2 thread, apparently "
The last update for the 9071 levers and most of the other etube parts was in September. So that means the 9071 levers will have newer firmware that will prevent it from working properly with your 6770 derailleurs, battery mount, and shifter. It just depends on when you updated your components' firmware last. " My firmware will be old...
801pe wrote:
You can only use 1 "A" junction in your system, choose either the 3 or 5 port. You can have multiple "B" junctions, I have 3 in my current build.
I presumed this too 801pe, but perhaps without the firmware upgrade, this "5-port" is just a dumb 5-port connection device, and isn't exhibiting an "A" type personality yet. :-)
Btw... here's the setup before and after. I'll let you know when I get it working.
Before:
After:
________________________________________________
Proud member of FISHTWITCH: beating you to T1 for over a decade, and working on beating you to T2...
