The bikes I have built came out of the box as a frame and fork, rear wheel/derailler and brake arms all installed...... I think that was it, everything else was in two boxes. The Stem extensions and the different length bolts, the Aero extension risers and the different length bolts, different length T bolts for the brakes, the brake noodle thingies that need to be cut down depending on the frame size (headtube length), chain, cranks and possibly more stuff aswell. I think the seat wedge was in the frame and held in place with some packaging tape.
Hope that helps
Chris
Ordered from a local shop...I am building it up myself as I am taking my Campagnolo Record 10s and SRM from my Slice and stripping the Ultegra off the RS... I unboxed the bike at home hoping to start the swap when I noticed that the parts were missing..the build instructions for the bike were also not included..the only reason I really knew parts were missing was because I downloaded the supplement from the Cannondale website....
Ive already contacted the shop, they are great guys and Im sure it will get sorted out...
Im just curious this "build kit" you talk about... would that be the risers and stem extensions?? I got the risers cable guides etc... the only things that appear to be missing are the seat wedge, and the extensions.. and the bolts for a zero extension stem... right now its stuck at 12cm and I cant go any shorter... well the bike is unrideable anyways with no seatpost...
I will also need to order the KP248 109mm spindle kit for my SRM just like I needed on my EVO for clearance...
Hope that helps
Chris
ParisCarbon wrote:
Hi, Ordered from a local shop...I am building it up myself as I am taking my Campagnolo Record 10s and SRM from my Slice and stripping the Ultegra off the RS... I unboxed the bike at home hoping to start the swap when I noticed that the parts were missing..the build instructions for the bike were also not included..the only reason I really knew parts were missing was because I downloaded the supplement from the Cannondale website....
