Quote:
Thank you Ian for your assistance in this thread.
Can I please get some assistance. I currently ride the new speed concept, size medium, long far topper. Using your video of getting stack and reach I came up with the following
Pad y (stack back of pad) 620
Pad x ( reach to back of pad ) 455
(pads have 14 degree tilt)
Seat height : 77.1cm
Rider height : 178 cm
Seat distance behind bb: 19mm with adamo race saddle
Enclosed is a pic of a club super sprint race for some idea.
I believe the stock canyon stem default allows for a reach of 460 is that correct ? When one is so close to the max setting would it make sense to order the bike with a longer stem to allow margin of error ? Does the long stem cover a shorter reach at all or is its minimum 460? I ride with larger bontrager race pads and have the elbows on them with some hanging off the back but that’s ok because of their size. Refer to pic below.
IamSparticus,
Thanks for your patience on this. In terms of the "stock Canyon stem default"... I don't think you're talking about the Speedmax CF, which of course comes with a stock stem that is sort of a mortal stem but not really and it is made by canyon. I think you're talking about an Speedmax SLX or CFR. I'm going to proceed under that assumpiton and if I'm wrong get back to me please and I'll respond in a more timely manner. So... the SLX/CFR (same geometry) ships in the USA with short stem (short cockpit) - but to say the Pad X max is 460 depends on the size of the bike - but again based on the context I think what you're asking is... "what is the Pad X range of the the proper size SLX/CFR for me?". Here we go....
With a Pad Y of 620 and a Pad X of 455 the right Speedmax SLX is size Medium, short stem, low spacer, and medium extension (everything I just listed as the proper front end config for you is stock in the USA - by that I mean you pull the bike out of the box it'll hae a short stem, medium extension and probably a mid spacer on it but in a box-o-bits that comes with your bike you'll have a low spacer and some wedges so you can add tilt). And you'll have room to push your pads forward another 9mm if you need that to a max of 464 or pull your pads back to a Pad X of 410. You're seat height will even allow for both water bottle bosses to be exposed behind the seat post so you can run that Canyon behind-the-post cage if you like.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
