Quote:
Hi Ian,
Many thanks for offering to help out with this. I am a bit confused by some of the sizing advice the canyon site is giving - for the Speedmax CF 8 it is showing medium and for the Speedmax CF SLX 8 it is showing small, even though the stated ranges of reach and stack for the two are identical (408-461 x / 581-691 y in medium).
I don't have a triathlon bike at present so here are all my details I can give you:
Saddle height 74cm
Inseam measured to sit bones 83cm
Height 177cm
Wingspan 184.5cm
Your advice for both models would be greatly appreciated, since stock issues might force my hand on which to buy.
frank0,
Yikes... I disagree with the site. I'm wondering how/why my disagreement exists and I can immeidatly think of two posibilities:
1) inseam to sit bones... hmmm for me that's too big a number. I want standard inseam: no shoes, floor to taint sorta thing.
2) you've accidently transposed the results: could it be a medium in the SLX and small in CF? Cuz that's where I'm headed.
Also, this is just an aside... the Pad Y/X ranges on the CF & SLX are not the same in the medim. The CF is a taller and slightly longer bike when we look at the pad ranges.
I suspect your Pad Y is around 625 and your Pad X is ~465.
If you got a Speedmax SLX (or CFR) you'd need a medium (the small will not go beyond a Pad X of 460 even with the long "stem"). So it would be a medium, short stem, either mid spacer or low spacer + tilt wedges, and medium extension. You'll have have bit a room to go longer in the cockpit and lots of room to go shorter, higher, and lower with the pads.
If you got a Speedmax CF you'd need a small (you'll be too close the bottom limit on the medium in both Pad Y and seat height). The 70mm stem that comes stock on that will verly likely satisfy you and you'll need to push the pads foward quite a bit. If I'm wrong on your Pad X and you want to ride out at 470 or a bit more that can be solved quickly and easy with an 80mm stem. The Y will offer you plenty of room to move above and below the 625.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
