Quote:
Hi Ian,
Firstly, thank you for what you have done with this thread! Such great information to takeaway. Great to see everyone coming together in such a positive and constructive way.
I am hoping you can help me. I have been in the market for the Speedmax CF 8 Disc Di2 for a long time now, and like everyone else have been impacted by the limited stock.
I did have a fitting done, on a mock up bike, and was recommended a size XS.
The Small has just come into stock and I was wondering what your thoughts are, is the Small suitable for me, in your opinion? My measurement are below:
Height: 168cm
Inseam: 79.9cm
Saddle height 68.5.
Handlebar X: 40.9 CM
Handlebar Y: 54.2
Another concern is the smaller wheels that come with the XS, hoping to avoid this.
Dino,
I can't do anything with the HX & HY but if there's Pad X and Pad Y on your fit sheet, I'd love to know those numbers.
I can say this... 1680 is 5'6" tall and 799mm is a 31in inseam (sorry, I still have to convert to get a perspective). If this is accurate, you have incredibly long legs. Without the fitting you had done I'd guess your Pad Y would have to be 600 and your Pad X around 415. But I'd like to hear if your Pad Y/X is on that sheet.
Let me know, Ian
Unfortunately I don’t have those numbers on my fitting sheet, suspect I’d get them when I take the bike for the actual fitting.
Is there any other info you may need to give me a guide on whether you think the Small Speedmax will be suitable?
Dino,
I have complete answers for you and am willing to discuss further here if need be.
If you're open to getting a bike fit done then GET FIT FIRST! Find a fitter who is educated in the triathlon position, experienced in those fits, and who has a dynamic fit bike. If you tell me where you live I might be able to direct you. The fitter MUST have all three of those elements. You'll go through a process that will ID your Pad Y & Pad X so we know for certain what size bike and what front end configuration is right for you and you'll come away with all your coordinates so that the fit is done before you even order the bike.
If getting fit first is not an option... then here I go:
Based on your morphology I think your Pad Y is ~610mm and your Pad X is in the neighborhood of 430mm. if I'm correct then, yes, a Canyon Speedmax CF size Small would fit you... with the 70mm stem that comes stock. I'm not at all worried about the cockpit distance; 430 is almost dead center in the Pad X range of this bike and you'll have 40mm to go longer or short to find perfect. The Pad Y however is another story. The lowest this bike goes is 600mm. So if my guess of 610 is too high you won't be able to drop more than 10mm. Here's are two reasons why I think you'll be fine
1) you've got crazy long legs for your height and folks like you (like me, like many) need a front end that is closer and higher than those built the other way with short legs and long torsos. It's more likely that you're Pad Y is 615, 620 or even higher.
2) if you do need to go lower than 610, you've got 10mm to be slammed AND you will very likely enjoy aerobar tilt where the base bar remains level but the aerobars clamps are loosened and the aerobar grips are pulled up higher. When this happens the arm pads drop giving the rider a yet lower position.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
