ianpeace wrote:
Quote:
So it looks like I might be able to swing a new Tri bike this year, right around the time that some of the new speedmax are becoming available this spring.
I'm looking like I might be out of the fit parameters though and would love some help.
To the back of my pads I'm a 676 stack which puts me smack in the middle of a large (I ride a 58cm in my road bike). I can go quite a bit lower and would like to work towards that. My reach is where I'm stuck. I'm at a 527 reach, and I actually think I could/should get my elbows out a little bit more (not much, but a little bit). That number puts me outside of the reach of even an XL. Are there different length stems available beyond what's on the geometry chart? I currently have TriRig closed back scoops on my bike now, and would probably switch them over to whatever new bike I get, they have a little more adjustability in them than normal pads I think, but not sure it's quite enough to deal with the discrepancy I've got on this frame. Any ideas? Help? Thanks in advance.
gregkeller,
I'm on a life-mission to protect the integrity and avoid the confusion in fit terms. To that - Stack and Reach speak to a place on the frame (top o' the head tube) and Pad Y and Pad X are all about our convorsation here (I even want to avoid the slippery slope of "Pad Stack and Pad Reach"). Thanks for coming to my Ted Talk.
I need to know if that Pad X of 572 is to the middle of your pad, the pit of your scoops, or the back of that pad? And I guess I also want to know.. the Pad Y of 676 you're specific about that being to the back of the pad - which is scooped, so are elebows sitting a bit below that?
Also - you looking at the SLX (same geo as CFR) or the CF? Or would you like me to spec' both?
Let me know (and I'd don't your seat height but it would be good if it's handy).
Ian
Ian,
Seat height is 80.5cm (I'm 187cm tall)
Sorry about my misuse of the terms. Pad X of 527 is to the back of the pad. I had standard zipp pads on the bike when I did the fitting, not the scoops. Same for the Pad Y. They didn't have the "scoop" in them and again measurements were to the back of the pads. When I put the scoops on, I did my best to keep my body in the same position. So I just confirmed my measurements on this bike with the scoops, and those numbers are correct if I measure to kind of the bottom back corner of the scoops (if that makes any sense)
I am looking at either the SLX/CFR right now. Unless you think I'm potentially a better fit on the CF.
Thanks in advance.
gregkeller,
No sweat - I mean, we're both coaches so we know there are 7 different meanings to the word "tempo" - I'm trying to avoid that in fit related terms :)
You can ride a Speedmax SLX/CFR for your Pad Y of 676, Pad X of 527 and it would require you to get an XL with the long cockpit (read "long stem"), low spacer, and pads foward 98%. Here's why I'm not nuts about recomending this to you... In the US the bike comes stock with the short cockpit and you cannot request hardware changes at time of order. I'm also not 100% sure how easy it is to get a long cockpit here in the us - maybe, today, they've got a rack full of 'em ready to ship but that hasn't been the case in the past. You simply ride too long for the Large to fit.
The Speedmax CF is better suited to you... in a size large, with the 90mm stem that comes stock on it, not much spacer at all ~25mm which is the height of the spacer under the stem so you'll ride with aerobar pedestals slammed, and now pads pushed out 99%.
I wanted to write those two prescriptions above to be respectful of your coordinates, your fit. I'd like to take a moment to expand on this if I may....You're almost 6'2" but I'm guessing (from the Pad X) that you've got a fairly long torso. If you'd come to me here on this thread and said "never owned a tri bike, I'm 187cm tall, what's my bike?" I would have guessed a Pad Y of 655ish and a Pad X of 505ish. You're riding 22mm higher and 22mm longer that what I would have expected. The cockpit distance (Pad X) doesn't worry me; some folks don't want their elbows right under the shoulders and they like extending foward a bit - fine. The Pad Y of +22 makes me wonder... first about crank length. The primay benefit of shorter cranks is that we can rider lower (assuming more out of the wind) and keep our hip from getting all bound up at the top of the pedal stroke. Now I've never seen your position, I don't know anything more than what you've given me here, but I wanted to just jot that down to see if it might cause an awakening.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
