I looked at the numbers on canyon website and I agree with your assessment. My concern is my fit was somewhat limited by my current bike. I realize I should get a new fit with the canyon in mind. What would you assume my padX and padY would be just based on my body and how would that effect frame size? I think If my saddle could move forward a bit, I had the 165 crank arms (which I can borrow from my son and try), My reach could extend forward some (that is what my fitter wanted but we ran out of adjustment), I would be comfortable with lower pads. If you assume all that is true and I went with a large frame, what would the front end setup look like? Would I need parts that Canyon doesn't sell in the states? Thansk for playing along with my what ifs.
Larry,
Thanks for coming back with more info - the more I have the better. There are some clues in here that suggest what your ultimate position might be and one of them is your setback is nearly 9cm - even with the shortness/noseless-ness of the ISM that's way far back and you're out on the nose....I'd think you might be out on the nose at a set back of 4-5cm. Anyway... if you had JUST come to me with your height and inseam I would have predicted a Pad Y of 675ish and a Pad X of 470 (to the
rear of the pad). My worry/guess is that your Spec'd Trans Comp has a set back post and you and your fitter simply couldn't get the saddle any more forward - you suggested that in your notes. So, if you were able to get the saddle more forward (steeper seat angle) then the whole front-end would go out and down and you'd move from your current Pad Y 740 & Pad X of ~430 (rear) to a Pad Y of 675 and Pad X of 470 (rear of pad). And, as a side note here - now you would make use of the shorter cranks because of the lower pad.
So, with all this in mind and a propable ultimate position of 675/470 you are dead center in the range of a size Large Canyon Speedmax CFR/SLX. In the USA that bike comes out fo the box with a short stem, mid spacer, and medium extension and those are the exact hardware bits you'd need to make that position. ALSO....if your seat height is 793 or higher (and i'll be higher with shorter cranks, it'll work on this bike). Also, if you ride for a while and think... "nope, these pads are too low" then you have the ability to go up nearly 50mm so you'll be safe in your up-down range on this bike. Also... with the short stem you can go out 15mm longer or back 40mm shorter with the same hardware (you can go out far longer with some hardware changes).
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
