Quote:
Hi Ian, thank you so much for all the help, your contributions in this forum are amazing.
I am looking to upgrade to the speedmax CFR.
I am currently riding a speedmax CF Disc size S.
My Current dimensions:
Saddle height: 688mm
Pad X: 460mm
Pad Y: 635mm
My height: 173cm
Inner leg length: 78cm
Forearm length: 35cm
Please help me with the CFR components sizes. And also should I get the flatbar or risebar?
Many thanks in advance!
Oned,
You are welcome. I truely enjoy this opportunity to help folks get on the right bike.
I'm struggeling with this a bit. Your legs are pretty long for your height and that is was keeps the ratio of pad height (635) and cockpit distance (460) something of a challenge. Your only option for a CFR is a size small. And with that size small you will have very little seat post exposed (no big deal, but I want it known because for some it's an aesethic thing), and you'll need the long stem and you'll need to push the pads foward to the max - and the mid spacer. It'll work. It's a little more extreme than I like but you could use a Rad Sport thing to get a longer cockpit if you needed it (and more aerobar tilt than the Canyon bits provide if you want that too). Becasue of the mid spacer - I would say get the flat base bar.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com
I like the pursuit of mastery
Twitter - @TriCoachIan
