re:
https://trackvalley.com/...lpha-fly-racing-shoe i did.
first i got the size 10 labeled shoe shipped, which turned out to be effectively a size 12. had to return it on my dime, (which was expensive from switzerland) and finally got a "size US 8,5" that fits slightly bigger then my standard nike 10. as you can see no box and a different thicker insole.
the rest of the shoe does really look and almost feel like the original. with the exception that it definitely does not have a carbon or any plate (it bends too easily to have one) and its probably not made of zoomX (or pebax) but more likely of something like react as it feels softer then standard EVA. the weight at 308gr compared to 227gr for the original supports this. see pics that compare it with a borrowed original in orange while the "fake" is white.
al in all it looks like a tempo next% made to look like the alphafly. but should it run the same or similar to a real tempo it might be worth figuring out your right size at $100 instead of 250.-
will report back once i had a chance to test them
you are welcome, you can fax me a beer!
