Damon,
recently upgraded to a P5-6 and have simply put washers under the front part of the pads using a longer bolt. I torque the bolts to the 3nm specs... no issues. I did this previously on my Ventus bars and Cervelo P4.
damon_rinard wrote:
Hi James,
As I mentioned, we haven't tested methods to accomplish any tilt, but obviously the two bolts could be spaced differently. Perhaps you or Jeff could try adding a washer or two to under the front bolt? I'm also imagining something like maybe a tapered spacer (wood? epoxy putty?) as long as the bolts still engage & tighten well and the plate is supported.
Just remembered the old Profile pads that used to mount with a single M5 bolt through a ball and socket joint for tilting in any direction. Something like that could also work.
Cheers,
Eric Reid
AeroFit |
Instagram Portfolio Aerodynamic Retul Bike Fitting
