HELP!
I removed the crankset (rotor 3d plus), greased the crank axel, and installed the crank. No more squeaking! Unfortuantly now there is (3-4mm) of lateral play that was not there before. I did not loosen the preload nut. I tried to adjust the preload nut on the non drive side but there is not enough thread on the crank arm. Is there supposed to be a spacer on the drive side?
Cajuntriguy: Oct 15, 13 6:06
