damon_rinard wrote:
Hi MTM,
Unfortunately, yes, the X-Low (also known as the Ultra-Low) extension is unsafe. At this time, 3T are not working on a replacement.
Cheers,
Thanks for the reply.
Not what I wanted to hear, though. Do you have any idea on whether they might look into a solution? I guess there can't be sold many of the X-Lo, because basically all of those people are now only left with the option of going to a good ol' non-integrated negative rise stem solution - definitely not optimal if you've bought a $10+k integrated superbike.
Maybe you can help me out a bit here (playing on your bad conscience and all :p) since it seems I might look into another setup than planned for next year. What is best aerodynamically: downward-sloping stem and extensions on top of aerobars, or flat stem with extensions below aerobars (creating a larger vertical gap between extensions and arm rests)? Elbows basically touching, for what it's worth...
