DougWelsby wrote:
My first couple of P5 rides outside this past weekend, and it was epic. 50km in the pouring rain to a 10km trail run race, then 50km back home. 8 degrees Celsius made it cold, miserable...and perfect to HTFU.
Now, on to the P5 part of the post. My aero bars are not staying put in the Aduro bars. My LBS torqued the collet nuts, and after a short ride outside a week ago, I torqued them some more, using an adjustable wrench and rag to protect the cosmetics. They are tight enough that I am afraid of breaking something by over tightening them, but they are not staying put.
After my ride on the weekend
the aero bar extensions have ended up rotated slightly in the Aduro bars. I cannot easily rotate them back, so I'll loosen the collet nuts and realign them, but I believe that they will simply move again with any sort of hard effort while pedaling.
So - any tricks or ideas to keep these from moving? I had thought about putting a couple of small dabs of tubular glue on the extensions before inserting them, but it is messy stuff and it could make for problems when trying to remove the bars if necessary for service or transport.
Suggestions welcomed...thanks.
"campled" replied to my posting, suggesting that lots of Teflon tape wrapped around the bars would help. It didn't. I also tried using some two-face tape, thinking that the adhesive properties would help. It didn't.
I have the nuts cranked as tight as I am willing to, fearing that any more will strip the threads or crack the nuts or threaded bar end.
What to do? The bars keep slipping, and right now I am pretty much unwilling to race on this bike as it's dangerous. I'm constantly having to adjust the bars while riding, and if I'm not careful, a little bit of rotational force to realign them moves my bike sideways (think of pulling on the handlebars - of course you'll change direction!)
Am I the only one with this problem? Have others come up with solutions? I'm thinking about something radical like drilling a hole completely through the nut/bar, and inserting a pin of some sort to prevent rotation. That will be a tricky operation, given that the gear cabling is inside the bar extensions - I'll have to remove the cabling before doing this.
Help!!!??? Thank you...
