thanks Carl for the answer, have a nice day.
Re: Official Speed Concept Owners Thread [Carl]
custom paint
I have had my sc for about 3 years and the paint has not held up well at all
I would like to get a custom job, nothing too crazy can anyone reccomend a good painter?
"If you want to experience all of the successes and pleasure in life, you have to be willing to accept all the pain and failure that comes with it"
Hi Carl,
I have a SC 9.9 2012 and I need to buy a new fork. Do you have the PN of that fork?
Can I order in the color of my bike? My SC is white, gray and red. Dou you know the price?
Thanks.
Thanks.
Re: Official Speed Concept Owners Thread [Fabricio99]
Hi Fabricio
I'm not seeing any (in any size) in warranty inventory for the colors you mention...maybe because the stock 2012 9.9 was black on black. The stock 9.8 for 2012 had white, gray and red colors...so did the stock 9.9 for 2010-2011...and the 2010-2011 9.8 WSD. If none of those links are your bike, and if yours isn't a Project One, you might try looking through the other models and years at the archive page so you can be sure what you've got. Almost all of the current inventory is 2013.
Anything not in warranty inventory could theoretically be created from scratch or by reworking something already in warranty stock, but that's a conversation for your dealer to have with their rep...on both price and availability/possibility.
Also, because paint fades over time, and because original framesets (frame and fork) are generally painted together, it would not be possible to guarantee colors matching exactly to your frame.
Carl Matson
Carl Matson
Hi Carl,
My bike is the same color of the link 9.9 2010-2011.
Can I buy this fork in this color in a Trek dealer?
Your dealer may be able to special order it via their rep. Make sure your dealer knows what size to ask for as well.
Carl Matson
Carl Matson
Hi,
I have a TSC 7.8 (2012) with the standard kit it came with, I'd like to replace the bottom bracket as it's started to creak and feels a bit loose.
Could I just clarify the following:
Thanks very much for any help.....and what a great forum, would be lost without this!
Regards,
Rob
- It's a BB86/BB90, right?
- If I've got the above right would this BB fit? http://www.wiggle.co.uk/...team-bottom-bracket/
- Is there anything else that would be common practice when making a BB replacement? e.g. bearings (http://www.wiggle.co.uk/...g-kit-carbon-cranks/)
- I've read that the ceramic bearings make very little difference to performance on a bike as the rpm is too low, is this right or worth going for ceramic?
Regards,
Rob
Re: Official Speed Concept Owners Thread [rob_hawthorn]
1) BB86...the 9-series is BB90
2) yup
3) I don't know how "common" it is to go ceramic, but the one you link to here will fit and it's the only ceramic bearing kit for BB86 that I'm aware of
4) no in-house testing on the benefits of ceramics vs non- that I can point to...I think there are great articles and interesting data already out there to help you make a decision/value judgement
ETA: First make sure it's a BB issue you're chasing...noises attributed to the BB can have their roots as far away as your saddle rails, and as near as pedal bearings or chainring bolts. Lots of stuff you &/or your shop can isolate and test before digging into your BB.
Carl Matson
2) yup
Carl Matson
Carl as always thank you very much. This type of customer service it makes a big difference.
I'm going to be sensible and just get the regular BB, ceramic can wait until I've hit a big FTP goal (or put another way, it can wait until I'm good enough to warrant the expense :-).
Thanks again.
Thanks again.
Hi,
I apologize if this has already been addressed. Is there a chart available showing the arm pad stack/reach for the new speed concept as there was for the original version?
Thanks,
Jonathan Blyer,
ACME Bicycle Co., Brooklyn, NY
Thanks,
Jonathan Blyer,
Re: Official Speed Concept Owners Thread [jonblyer]
Re: Official Speed Concept Owners Thread [timtri13]
how does that fuel cell fit with the down tube? Any close up pics of that?
Re: Official Speed Concept Owners Thread [zachboring]
Final build although my wife hadn't perfected the bar tape colour....
thank you.
Jonathan Blyer,
Jonathan Blyer,
Just got the carbon computer cage for the 2014 sc 9.9.
1) is there going to be a specific bottle with a straw available?
Similar to torhans or profiles bta.
Re: Official Speed Concept Owners Thread [ebroker97]
nope, the idea is that you can use any easy to find, relatively inexpensive standard bottle ...or, I suppose, any of the straw-added bottles which fit in a standard cage.
Carl Matson
Carl Matson
Thanks for the quick reply :)
I'll look around. Would like to stay in aero position while I hydrate.
Next topic...
Have a quark Elsa. What is the best way to mount the magnet?
Next topic...
I believe most people are gluing power meter magnets inside the rear brake cover.
Carl Matson
Carl Matson
I have a problem with the lid on the speed box 2 coming off - typically hitting bumps. Does anyone have a solution besides taping it down each ride? I have a 9 series 2014 SC
I glued my quarq magnet to the frame (down low on the chainstay) using the included two part epoxy. I then colored the epoxy black (to match the frame color) using a marker. You can't even see it with the crank on.
Re: Official Speed Concept Owners Thread [bnlea]
bnlea wrote:
I have a problem with the lid on the speed box 2 coming off - typically hitting bumps. Does anyone have a solution besides taping it down each ride? I have a 9 series 2014 SCHave the lid issue on my 2012 SCs and it is definitely less of an issue on my 2014, but taping it down is still the best solution, in my opinion, if you want to keep your flat kit with you.
The SCs fit me well, so I just look at the lid tape job as the cost of doing business.
Team Kiwami
Re: Official Speed Concept Owners Thread [sommer]
Can you post a pic. I want to get an idea on how low and close you got it.
Thanks!
Thanks!
I tried to capture it with a photo. Not sure it really helps though. The magnet is touching both the chainstay and the bottom bracket flange. That puts the magnet about 1mm away from the Quarq and in perfect alignment.
I'm attempting to post a photo in this reply and I'm not having much luck.
Does anyone have an idea of delivery time for a 9.9 Frameset?
