Hi iyun
The EW90 box wasn't designed for internal installations... so we added two sets of thin-walled sections inside the stem cover labeled "Di2 holes" which you can knock out for ziptie access. I see you're using one set and your box sits pretty low...using the second one should move your EW90 box up a little further. There's a similar knockout "notch" towards the front of the stem cover which is intended to give you an exit port for the eTube wires coming out of the frame and bar. There's plenty of room to hide the excess wire inside the bar, the high-near stem you've got, and to some extent the mono-spacer, which would avoid the big loop you've got going.
Carl Matson
Carl Matson
