Toby wrote:
Grant.Reuter wrote:
burnthesheep wrote:
h2ofun wrote:
For me, I feel I wear out much sooner trying to push higher RPM's, which I see with my HR going up, vs lower RPM. Something doesn't jive there.
I guess maybe it's a tri vs. roadie difference. I'll do a wattage grinding up a climb at 70rpm or do the same spinning out my turn on the front. It costs me the same amount of kindling in my matchbook. But then again, I train both. That's just me but I ride with power and HR and don't see an appreciable difference.
That’s the one thing that doesn’t sound too absurd in this whole thread. High cadence can be hard to train and I’m not sure if there is any consensus on which is best for Tris. Pretty sure Sutton had a blog out against it a few weeks ago saying to stop training like a cycling TTist because Tris are not the same and you don’t bike enough to be able to handle the high cadence.
I normally run 90-100ish now but when I was racing more frequently I was probabaly in the 80s. Don’t know if it makes a rats ass of difference it’s just how I ride in training so I end up racing at the same cadence.
My heart rate is higher when I left myself go to natural cadence of ~95 than when I hold it ~80. Does that mean I'm more efficient (good), or just that I'm using leg muscle instead of aerobic power (bad)? Something I'll have to figure out.
That sounds correct. I’m going to butcher the terminology, but it should at least make sense. higher cadence at the same power is going to require less force per revolution, so it’s going to be less of a muscular process than say grinding out at 60rpm. If you’re grinding out at a lower cadence it should cause your HR to be lower at the same wattage compared to running at 100rpm.
So for shorter races you can handle the higher cadence due to the force you’re exerting as the race gets longer it doesn’t make much sense to run high cadence as it exerts more on you’re heart and lungs and you’re not putting out enough power at an Ironman race to need the high cadence to lower the muscular force.
