Carl Spackler wrote:
Dave,
Sorry if you already answered this but what's the difference between AR FRD and AR1 frames? Is it that FRD is for electronic shifting only or more? And can the 1 be set up for either?
The AR FRD and AR1 frames come from two different molds and two different carbon fiber lay ups.
The AR FRD represents the industries first use of Oxeon's TeXtreme material in a frame lay up. This incredibly strong material allows a drastic reduction in the material needed for strength. Only Campagnolo and Shimano have released products will this technology and it is only available today in their disc wheels. You'll see it used on dozens of brands in the coming years. It is a huge step forward owed to the patented process for creating the 76gsm fabric itself.
The AR1 use a mix of our UHC Ultimate and UHC Advanced carbon fibers which are then covered by Toray's 1k fabric weave for impact strength. Using 3sqm of 100gsm 1k vs. 3sqm of 76gsm TeXtreme yeilds much of the weight difference of the two frames. The AR1 mold then adds ~30g of internal patches of reinforcements at the mechanical cable entry and exit points and uses a much larger access hole in the BB for a nylon injected cable guide or junction box cover.
The FRD road models are compatible with the current electronic systems on the market from Shimano (Di2), Campagnolo (EPS) and Tiso and should work with the hydraullic shifting systems with yet-to-be-developed cable guides.
The AR1 has the same convertible cable guides that our Z, ZW, and Virtue9 bicycles use although the AR1 would still be routed through the top of the top tube if run with electronically controlled shifting as you see in my photo above. There is no need to run the wire to the downtube as it is routed on our Z and ZW models. Both the AR FRD and AR1 feature a clever integrated 2 gram BTR-2 Di2 internal battery holder.
Even the frame of the
AR5 from 2014 is ~8% lighter, 30% stiffer and 25% more aerodynamic in a -20/0/20 sweep than the previous generation AR1. Today you can buy a complete AR5 for $2500 which is a better
frame from every metric available than last year's $3000 AR1 frameset (!)
We'll have the demo truck through NorCal with AR4 models later this fall if you're interested in an extended test flight.
-SD
https://www.kickstarter.com/...bike-for-the-new-era
