Hi Candice
I bought the 400 but unfortunately i can't get the system to work on the new speed concept with both the bottle and computer mount working together.
The first picture in your post using the mini mount plate was how i wanted it to work - with the bottle and the computer mount being attached to both ends of the mini mount. Unfortunately the picture on your previous post isn't like my 2014 speed concept 7.5 - which is pretty much standard. If you look a picture of what my aero bars look like online (
http://aerogeeks.files.wordpress.com/.../07/asset_168514.jpg), you can see on my bike the elbow pads are attached to a bar that is screwed on top of mono aerobar which i cant see in your picture. Its possible to attach the mini mount to the two center holes in the monobar with spacers only if you turn the mount around front to back, however when you do this, there isn't enough length to then attach a waterbottle cage and have enough room for the computer mount at the front with the water bottle in.
The second option of just screwing in the bottle cage is only possible by drilling another whole into the bottle cage holder so that you can use those centre screw holes.
So it seems in either way you have to drill some holes into the mini mount or water cage to get it working. Unless any other owners have found another way? I'm a bit nervous about drilling new holes but there doesn't seem like any other way.
Are there any plans to release anything bta specifically designed for the new speed concept?
