wickert wrote:
Andy, thanks for bringing this thread back up. I've meant to ask this some moons ago but kept forgetting it: what about track/velodrome runs?
Ah, good question!
We have considerable track modelling experience. In some ways, it's the most difficult VE problem around. There are numerous challenges.
The issues are that the VE equations track the CG height, that the speed sensor measures *wheel* speed (not CG speed), that the tires are not always at 90 degrees to the bank, leading to slightly small wheel circumference, and that velodromes each have their own tailwind "microclimate", generated by the combined movement of the whole day's activity around the track.
All those things conspire to degrade VE accuracy.
If you ignore all that and get a pretty good handle on tire Crr, then you can still use Aerolab to do A vs B relative CdA testing. It works well, and produces results that are good enough. You don't need to do anything but ride the black line, or some other constant-height line.
Hope this helps...
AndyF
bike geek
