RChung wrote:
Tom A. wrote:
RChung wrote:
lanierb wrote:
On the Crr testing issue, if CdA and Crr are changing with speed, how about testing at identical speeds but adding/subtracting weight? Has anyone tried this approach? Once my shoulder heals I could give it a go with water bottles filled with lead. (Thinking out loud: lead would add significant weight so thinking that I would need to adjust tire pressure to hold Crr constant.)
That's exactly what I've been proposing for a while as a validation and precision check (and what Pierre (bugno) and I were chuckling about a few posts above). I've done a couple of these "delta mass" tests with empty and full water bottles. I used to use sand but then switched to small nails. I didn't want to use lead weights both because I wanted to re-use my water bottles and also because lead shot is kinda expensive. (On the other hand, a penny weighs 3 grams so $5 of pennies weighs 1.5kg). For me, with my other parameters, 1.5kg in mass increases rolling resistance force by the equivalent of ~.0001 in Crr, or around 10cm in virtual elevation per km. So over a 3 km run on a windless day, I was expecting to see a change in VE of ~30 cm between empty and loaded tests, which is pretty noticeable. So I did that, but at varying speeds, and was observing a VE difference close to that. But then the wind came back up, so I didn't get to do more tests.
Is this a case where you'd want to use Gatorskins or Tufos? (To get a bigger "signal")...the larger the Crr, the larger the absolute increase in rolling resistance force per kg, no?
Friends don't let friends ride Gatorskins or Tufos.
Not for pleasure...but, this is for SCIENCE! :-)
