Hi, I'm new to this forum. I have a question about repeatability of CdA testing obtained using the VE method.
I've been a cyclist for about 25 years (mainly MTBāing - sorry!). In the last few years, though, I've got into time trialling. I'm an aerodynamicist as a profession, albeit for an aircraft manufacturer, so technical side of time trialling really interests and appeals to me.
I want to focus on improving my position and CdA, which is in the 0.27-0.29 region (so there's room for improvement!). After some haphazard experimentation with field testing over the last couple of years, this summer I spent some time properly researching field test techniques, and came across Robert Chung's VE method, which I really like and am now using.
I have fully read this thread and have used all the useful information and comments to refine my test technique. However, I still have the feeling that the repeatability of my testing is quite poor. The repeatability I'm getting is around 2%, for CdA differences between two tests within the same session.
I was wondering what level of CdA repeatability other people are getting when doing VE field tests? Here is a few details about my test protocol. Sorry this is long, but I hope more information is better than not enough:
1) I use a 1-mile oval road on an industrial estate, near Bristol in England (
https://www.strava.com/...62528?filter=overall). It has approximately 30ft of elevation change. The slowest speed is about half the fastest speed when ridden at constant power. No braking is ever required. There is no traffic at the weekend. The only downside is the asphalt is quite rough (slightly rougher even than average UK roads!).
2) I do 5 laps at a time, so each run is 5 miles & takes 13-14 minutes.
3) I use a Stages left-hand PM. I know this is not ideal, but it's all I've got.
4) I keep my power at 230-240W, which is tempo/sweet-spot for me in my TT position. I know it's not necessary to keep power constant, but my thinking is that any left/right leg imbalance will then be similar from one run to another if I keep the power similar. It also helps me correct occasional signal dropouts when I know Iām riding at constant power.
5) I now do three runs per session, in an A/B/A configuration sequence. Three runs are about my limit (~40 mins total), and it also gives me a useful workout! I've tried doing a 4th run, but fatigue was affecting my form and position.
6) I now use a GSC-10 speed sensor, and have GPS turned off (thanks to reading this thread).
7) I analyse the VE profile in Excel, mainly because I like to know what's being calculated and I can manually identify and correct the occasion zero due to dropouts. In any case, I have checked my Excel-derived CdA against Golden Cheetah, and the CdA agreement was within 0.001, so I'm confident there are no bugs in my spreadsheet.
8) I have done one session where the 2nd run was done slower at 100-150W instead. This slower run allowed me estimate that CRR should be 0.006 instead of the 0.005 that I initially estimated.
9) Completely calm days (<3-4mph) never happen in the West of England, unfortunately. On a āgoodā day, the reported wind speed is about 5-10mph, which I understand corresponds to wind speed at 10m. I therefore target those 5-10mph days to do my testing, which happen about approximately 20-30% of the year. Most of the days in the year are more windy than that. I realise this wind speed is not good for VE testing, but I can't do a lot about it. My hope is that within a single session the wind speed will not change much, but it's just a hope. I am certainly not expecting good repeatability between tests on different days, because the wind will certainly be different.
There are one or two remaining things I can try to further improve things:
- Stay in the same gear. Currently I shift across a few sprockets to avoid the spinning too fast or grinding too slowly (which is more a personal preference than a real constraint). I am fairly consistent between runs I think.
- There's a chance my body position between the first and last run of the A/B/A sequence differs, due to fatigue, especially my head position. One thought I had is to attach a zip tie to the stem to 'tickle' my chin so I know my head's in the right position.
- An bike-mounted anemometer would be brilliant, to try to adjust my calculations for wind variations, but I can't anybody selling them at the moment. The cost may be an issue anyway.
Any other tips or suggestions would be appreciated.
The repeatability I've achieved for three sessions so far has been 0.018, 0.005 and 0.006. This is the difference in CdA between the first and third runs (i.e. in identical configurations). Only my most recent session was done using the GSC-10 sensor, though, so I am taking that 0.006 value as my only really valid repeatability data point so far. A 0.006 delta-CdA equates to just over 2%. Of course, I need to gather more data to see whether this was a 'lucky' repeat, or an unlucky one. With enough testing I could get a repeatability standard deviation, I guess.
Could other people that have done multiple VE field tests please let me know what level of repeatability that they get within the same session please? Is 2% typical, or do people achieve much better? This information would help me decide whether I need to keep working to refine my protocol, or accept it as it is.
Sorry for the long post.
