cyclistgo wrote:
My question is about if it´s possible to determine in stable test Cda and Crr or is necessary change velocity.
And with it we can get lot of combination numbers for Crr and Cda.
Estimating CdA and Crr from the same data set is possible but it's pretty demanding of good data and good experimental technique. The short answer is it's necessary to change velocity. The fuller answer will require a little dip into statistical estimation. I'll try to keep it short and understandable.
In order to estimate two unknowns, you need to have at least two equations. If all your data are taken at a "stable test" at a single speed or power, you'll only have one equation so the system is undetermined. What's also true is that if the data vary but only by a little bit, you you can solve for estimates of CdA and Crr but the data are *nearly* collinear so although you were able to do the estimation, they're estimated poorly.
So, if you're trying to estimate both CdA and Crr from the same data set, you have to have a pretty wide range of speed and power--and it's good to have a lot of equations so you can check the precision of the estimates (there's a bunch of statistical mumbo-jumbo embedded in the last part of that sentence). A secondary issue is that you'd like the speed and power to be pretty accurate and precise, and a third issue is that you don't want there to be wild swings in speed and power because some power meters are a little sensitive and laggy in responding to big changes in power.
All together, if you want to separate CdA and Crr, you need accurate data and a wide range in speed and power.
Andy Shen once suggested a monotonically increasing speed protocol for velodrome testing: start slow and increase speed a little bit each lap. There are other ways to ensure that you get a pretty wide range in speed and power, but this will work. Find the top power you can sustain for a couple of laps, then start at perhaps half of that power, then each lap increase speed smoothly so that after 10 laps or so you're at your max that you can sustain without ruining your position. If you can, do a couple of extra laps slowing down in speed and power. A protocol like this ensures both a wide range in speed and power, and also keeps sudden changes in them relatively small.
