I did my first attempt at field testing this weekend.Didn't have too much time but was able to get a 5 loop uninterrupted run on a small loop in a nearby park, closed to traffic, no one around (before a roller blade guy showed up). It's completely flat and about 525m long as measured by my speed sensor.
Wanted to run through my protocol and see if I'm on the right track here or if there's anything extra I need to do.
1. Measure weight (bike 10.2kg, suit+helmet+shoes 1.8kg, me: 73kg). Total weight 85kg
2. Found a wunderground weather station less than a mile away from the park
3. Using Garmin 520: GPS turned off, using the Garmin hub based speed sensor, disabled auto calibration and set wheel circumference to 2096 (700x23c).
4. Pumped tires to 80psi (HED Jet 6+ with GP4000s 23c and butyl tubes). Assuming a crr of 0.00411 based on
this test 5. Zero PM (using crank P2M).
6. Rode a few loops to get familiar with the course and gauge speed in corners etc. Averaged around 190-200W. Kept it in the same gear, no braking, no coasting.
7. There's an actual start line (they do crits on this course). Hit Lap button on Garmin at the start line and rode 5 loops all recorded on the same lap / interval on my Garmin.
8. Download data in Golden Cheetah
9. Calculate air density based on weather data (69F, 100% humidity, 0 wind, 30.01 pressure) -> 1.21821
10. Fire up Aerolab
- set crr, mass, Rho
- Elevation line looks almost flat - as expected - can I just mark the "constant altitude box"?
- move CdA slider to make blue line as horizontal as possible? There are some micro dips in the line but every hard to align.
Question: how do I make my numbers not suck? just kidding... but if you could give me some feedback on my protocol that would be awesome. I plan on going back the following weekends and experiment some more and see if I can get repeatable numbers before I start doing some A/B testing.
EDIT1:
Okay... Read a bunch of the previous threads and I'm adding these findings:
- Fudged air density calculation: correct should be 69F, dew point 69F, pressure 30.1 ==> 1.19816
- I need to loop my Garmin every loop. It helps visualize the VE for every loop of the run and weed out loops with anomalies. I did not do this and ended up with one interval with no way of knowing where each loop starts and ends unless I split by distance.
- Crr of 0.0041 as per the roller test is probably not accurate on the road. This loop while it's not super crappy asphalt is not exactly super smooth either. Problem is that the difference between a Crr setting of 0.004 and 0.006 is the difference between solving for a CdA of 0.277 and 0.240 which is pretty significant. How do I get a better Crr estimate?
- I'm at sea level and since this is a flat loop with a 100m radius, actual elevation changes are probably not important so removing the Garmin elevation data and then trying to flatten the VE graph as best as possible should be the way to go.
- Set Eta to .98 for crank PM
- Will try to mark the course turns to make sure I take similar lines for as much as possible.
What's your CdA?
